Connect multiple W600 to W100
Hi everyone
Currently, I have everything set up using Zigbee.
I’m aware of the FAQ entry stating that currently only one thermostat can be associated with a W100 to control the temperature and also that this will come “in the future”. Does anyone know of a roadmap on when this will be possible?
On the other hand, I noticed that you can select a certain W600 and then create a group containing other thermostats. You can then connect the W100 to one of these groups, but then the buttons stop doing anything. Creating a group and then connecting the W100 to the first (or any other) W600 directly does not propagate a temperature adjustment to the other W600s in the same group.
Or would I be able to do this via a HomeAssistant automation? Almost all of our rooms have more than one heater, one even has 5.
cheers
Lugi
hi, welcome aboard!
This post may help.
This does not answer the question. I also would like to know if it is possible to bind the W100 to multiple thermostats or AC controls?
For example, i would like to bind my W100 to both the W600 and the M3 climate control device. Then i would like to use the middle button to toggle control between heating and cooling. Is that a planned feature?
This is the image from your website. I would like to use the W100 to control both heating and cooling.
thanks for the reply. I have been using HomeAssistant for about 10 years now, but since I’ve moved into a new house a few months ago, which is completely different, I will have to reconfigure everything. With 14 W600s, 5 W100s and many Hue devices and other stuff, this will take some time…
Let’s see, how it goes.
