Forced to change router from ISP. It forces me to use new DHCP settings. Can’t get G5 Pro and G410 to connect even after factory reset (failed to bind)
My old network was 192.168.0.xxx. I’m forced by new ISP to use 192.168.1.xxx. Trying to reset network settings on both devices fails with cannot bind to account. So after doing factory reset (after removing from Aqara app and apple home app) they still won’t bind.
Please help!
Hi there.normally when you change the router or ISP company you just need to rename the new network same as the old one and use same password.now that you have reset the devices follow this steps :
Clear iOS Stale Matter Credentials
-Verification: Open Settings > General >
Matter Accessories again and verify the device is no longer listed.
-Restart Mobile Device and
Network Hardware
2 minutes
Stale mDNS (Bonjour) cache on your phone or router often routes discovery requests to the old 192.168.0.x address space.
Verification: Reconnect your smartphone to the 2.4 GHz Wi-Fi and verify it has acquired a valid 192.168.1.x IP address in your Wi-Fi settings.
  • Perform Full Hardware Reset on Agara
Hub/Device
Clear local token
Verification: The indicator light should continuously pulse yellow/amber, indicating it is in binding mode.
Hi. Thanks for trying to help.
I did say that I couldn’t do as you suggested above because the IP address domain was changed by force. So even though I DID keep the wifi name and password the same, the ip addresses were wrong. (Old = 192.168.0.xxx / New = 192.168.1.xxx)
However, I wasn’t aware of the matter cache on my iPad. So I’ve delete those and will try again. Thanks for that tip.
No matter what is the IP your router once connect an device it gives automatically the IP more when you reset it try resetting it by pressing 10 times in a row this will factory reset the G5 so that old ip you had will not matter anymore
As expected. It didn’t work. “Account binding failed. Please try again.”
Why are these so hard to setup!?!
They are not hard something you do wrong because on August I changed my ISP too and they added an new router with an new IP and I had no issue with my smart devices all were connected automatically once I added the same name and password on my router.did you connected your phone to the 2.4Ghz band?also did you factory reset it by pressing 10 times the power button?
I already said I did the factory reset and it didn’t work!
And just because it was a lovely time for you means you got lucky; look at the number of posts about ‘account failed to bind’!
They. Will. Not. Connect.
I didn’t say that I got lucky I say that something is with your new internet connection witch doesn’t let you connect devices.my be give more details :
Did you proper setup your router?
Did you check that if they are properly removed from the matter accessories ?
@Aqara_PM_Donie could you give some help here?
What kind of internet router did you receive from your provider?
It may be possible to configure the IP address for the home network and thus rule this out as the cause.
That error message sounds a bit like an account issue. I’d suggest trying to log out of the Aqara Home app and then log back in. Maybe some tokens have expired in the background. Do you have an internet connection? Did you have the “Anti-Theft Lock” option enabled in the settings? And are you using the same Aqara account as before? You haven’t changed the region settings in the Aqara app, have you?
Hi Zoe, I feel your pain. Few things are more frustrating than a camera that sees the Wi-Fi perfectly well and still refuses to cooperate.
Good news on one point: once the devices are factory reset, the change from 192.168.0.x to 192.168.1.x shouldn’t matter at all. They get a fresh address from DHCP like any other device. So the subnet itself is probably not the culprit.
“Account binding failed” usually means the camera joined your Wi-Fi fine, but couldn’t reach Aqara’s servers to finish the binding. With a brand new ISP router, the usual suspects are a built-in “security” or “safe browsing” feature, DNS filtering, parental controls, AP/client isolation, or WPA3-only mode. Those features often block exactly the kind of traffic these cameras need (cloud servers and time sync). Turn those off temporarily, make sure 2.4 GHz is enabled with WPA2, and try again.
The quickest way to know for sure: set up a 2.4 GHz hotspot on a spare phone and try binding the G410 to that. If it binds right away, you know it’s the ISP router, and you can move the camera back to your Wi-Fi afterwards. If it still fails even on the hotspot, it’s more likely an account-side issue, like the device still being tied to your account or Anti-Theft Lock still being active, as JohnD mentioned. In that case, Aqara support will need to release it on their end, so mention both serial numbers in the ticket AqaraBot opened.
Hang in there, these things are usually one silly setting away from working.
The devices were locked out on an account level at Aqara. Aqara had to reset them at their end then binding works fine.
