H2 US switch won’t reset
I’ve installed a H2 U.S. dimmer and a H2 U.S. two button switch. The dimmer switch installed easily added into Aqara and HomeKit. The other switch no matter what I do will join Aqara or HomeKit. I’ve tried the two tap then hold for 5 secs reset and the quick 10 tap reset method and neither does anything to reset the switch.
This doesn’t apply in this situation. The switch never joined the Aqara app or HomeKit. Only the dimmer switch did.
Hello. Are you scanning a QR code? What gateway do you have?
Bear with me a moment so I can get the full picture.
When you wire it up is the switch itself responsive to control the load?
You are attempting to reset in order to get into pairing mode. Is that right?
Finally, what steps are you taking to pair the H2? Assuming scanning the QR code in one app or the other…
Have you tried manually inputting the code?
I feel your pain. I am hassling with the same issue for three H2 dimmer switches. It doesn’t look like anyone has found an answer?
