Just got new U200 smart lock is the 3.0.0_0075 a good firmware?
I have received a brand new Aqara U200 lock and it is on 3.0.0_0075 - when I check the latest firmware that I can update is 3.0.0_0084 - is it safe to update to it?
In the update Log it says “if your current firmware works fine, you can safely ignore this update” - so my question is - is it safe to update to it.
I already have another U200 (Kickstarter) and it works ok with the 3.0.0_0084, but I have read that many people have issues with the latest beta firmware and just want to know if there are major improvements from the factory 3.0.0_0075.
Thanks.
Hello @radi7024
It is better to follow the instructions, if your lock works well and there are no problems, then stay on firmware 75, if not, then update the firmware.
I recommend staying on .75 as my trouble started on .84. Read here for more info as it’s been discussed for months:
Hello, if your current firmware is working properly, we recommend that you do not upgrade to V0084. If you need to use the remote periodic password feature, we suggest waiting to upgrade to V0085, which will be more stable.
I turned off the beta firmware updates and now it tells me to update to V0077.
But again it says that if I am ok with V0076 to not update.
So my question is if the V0077 is also safe.
I don’t use the periodic password feature!
And now for several days the lock works great so I am inclined to stay on V0075.
I am on firmware 080 since July. it works fine.
