My weekend project: Balcony LED lights
As the spring is here, it gave me and my wife a lot of energy to do a lot of things around our apartment. One of the things was cleaning up our balcony after winter and changing our faux grass outdoor carpets to a nice acacia panels from IKEA.
As soon as I mounted those wood panels I looked at the balcony and said to my wife that she was right about them. So I thought “what about making some nice LED strips for our romantic rights on the balcony?”
So without further ado - here’s a before and after! And I’ll describe my whole process of mounting the T1 LED Strip below in a moment.
BEFORE
The photos seem bright because it was just about dusk and I used night mode on my iPhone
AFTER
The LED strip here is at 10%, 3000K
The second photo was taken with iPhone’s night mode.
Stay tuned for an update below how I made it and installed it!
Mind you, if you wish to do it yourself, please be aware you need some electrical skills, especially with soldering. The Aqara LED Strip has 5 pins which are very close and thus it is harder to solder the strips (you might cause a short if you’re not careful).
The update is in the replies to this post
Cool!
PREPARATIONS
Before I started my work I made some photos of what I used for my little project.
What I used:
  • Aqara LED Strip T1 (2m) + 2x 1m Extension (4m in total, but I only used 3.4m)
  • 4m of LED profiles/channels (angled 30/60 degrees, those can be mounted either on the 30 or 60 deg side)
  • mounting tape (the blue tape in the picture)
  • mounting adhesive
  • 6m of 5-core LED cable
  • electrical silicone sealant
DAY 1 PART 1: Installing the LED profiles
My profiles are 30/60 degrees, which means they allow to mount the LED strip at an angle and you can choose either side.
I cut the LED profiles into the following sections: 80cm, 50cm, 50cm, 100cm, 117cm, 83cm.
The LED profiles are made from aluminum and they will expand and shrink during the year so they need to be cut in parts because of this. Another reason of this is that I have rods below the railing and I cannot mount one continuous strip underneath.
The mounting adhesive will take about 24 hours to harden so I used the two-sided LED mounting tape to secure the tape.
Here’s the tape with a bit of glue, it’s not much, but it’s enough. I have used the same glue to install the hooks for a balcony net, and the net is tight and holds the vines for 3 years straight. So even with this amount of glue, it’s not going anywhere.
Here’s the LED profiles installed underneath the railing (ignore the rust, I’ll fix it later). Notice I left some space near the edges so the profiles can expand during summer.
DAY 1 PART 2: Soldering
This took me a few hours, especially because I wanted to be careful with the pins. At the beginning, I took this picture of the wire colors for future reference:
My wires are different colors (black, red, green, white, yellow), so this picture was also a future reference for me. Notice how close the pins are, it’s really easy to leave some solder that will connect the two pins.
For example, if you leave solder between GND and WW, then the whole strip will be lit with warm white 100% of the time (the strip will not be able to turn it off).
So I soldered a 3m wire at the beginning, and then used 20cm sections to connect 4 strips (80cm, 100cm, 100cm, 60cm, 3.4m of LEDs in total).
If you do it yourself, remember your connecting wires have to have a few cm more because the LED strip will shrink a bit with the channel during winter. And the wires have copper in them - they will also shrink.
After I finished soldering, I tested the LED strip - all good! So now it was time to seal the connections.
I used the silicone electrical sealant to secure the connections. After about 2 hours, when the outer layer was kind of solid, I added the heat-shrink tubing to make it a bit more stiff and less prone to mechanical and weather wear.
Tip: High humidity and above room temperature (28-35°C) will cause the sealant to dry faster. Do not use any hair dryers to speed up the process, it can blow the wet sealant away or unsolder electronics.
After installing the tubing, I used the silicone again to seal the little crevices at the edges of the tubing (it was not 100% tight).
Now, with the silicone inside and outside, I left it to dry for 24h.
DAY 2: Installing the LED strip
Now, as the glue of LED profiles hardened and the sealant dried, it’s time to install the LED strip.
I pulled the strip through the railing support and put it in the LED channels.
Notice that the connections are loose - it’s to allow them to shrink. The cables are pointed downwards so the rain will go onto the floor, not into the LED channels.
The LED transformer/controller is installed inside, and I put the cable between the floor panels and used the cable channels to secure it in place (so it won’t be moved when the door is opened/closed, minimizes the wear on it).
Of course, the cable is not tight, there’s a loop before the channel and another loop at the end of the LEDs - those will allow the cable to shrink in winter.
And the most important part of this whole project - wife is happy :grin:
Haha ! I like the last sentence- that’s definitely one of the biggest difficulties in a smart home :joy:
Yes, to be honest I’m kinda surprised because she is very approving of my recent ideas :grin: Suspicious… :thinking:
Beautiful result! Well done!
Great project… well done! Thank you for the instructions too. :+1: :slightly_smiling_face:
Really impressive! I wish I had your execution ability. :rofl:
The ambient definitely benefits of this project. Looks cozy and it’s wife approved! Thanks for sharing the steps with us!
Good job! It’s so much fun to take on little projects every now and then.
Looks awesome!
very very very cool
and wife approved? even better
Hi! If you’re still reading, check out the followup with some convenient automations
Just started raining heavily, took some pictures, here’s one of them
June update: There is a lot of green now, it’s really cozy. And it’s really nice to read books (on a kindle) with a cup of tea at night.
Nice! And the happy wife makes it all worth it.
