Only Matter+Thread+Apple in new home
We are moving to a new home in a new city. I’d like to start fresh with everything Matter over Thread, with only Apple TV and HomePod as hubs/relays. I’d like to avoid additional hubs from device manufacturers, or having to maintain any HomeAssistant or Homebridge nodes.
Is this a configuration that is supported?
If you run this in your home, what has your experience been like? Any gotchas? What do you love or hate about it?
@HeapOverrun Your configuration idea aligns with the core goal of the Matter protocol—interoperability across ecosystems. Theoretically, since Matter aims to enable device compatibility across different brands and controllers, using Apple TV and HomePod as Matter/Thread hubs/relays should work with Matter over Thread devices.
Thread networks, which Matter over Thread relies on, offer advantages like easy deployment, communication security, reliability, low power consumption, and scalability, which can enhance your smart home stability. For example, Aqara’s native Matter devices (such as the Motion Sensor P2) support Matter over Thread natively, ensuring compatibility across brands.
However, there are a few potential “gotchas” to note. First, ensure your router supports IPv6, as Matter devices typically require it for setup. Second, if you have multiple Thread border routers (like Apple TV and HomePod), try to connect them to the same Thread network to avoid fragmentation and ensure stable coverage.
Since your setup avoids manufacturer-specific hubs, focus on devices explicitly labeled “Matter-certified” to ensure seamless integration. If you encounter issues during setup (e.g., device pairing failures), double-check your iPhone/iPad’s iOS version (needs 17.5+ for Apple devices) and ensure your Apple hubs have the latest firmware.
Have you already selected specific Matter over Thread devices for your new home? It would be great to hear about your experience once you set it up—feel free to share any wins or challenges! If you run into technical hurdles, you can contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
I am not sure, but I think some older matter devices may not have enough memory to save all the keys from different ecosystem. example, some of my nanoleaf bulb stopped responding after adding them to 3 (apple, google, home assistant), but is stable when I only add them to one (apple)
Matter is still in its infancy, and there are several pitfalls to watch out for. Many features that are standard in Zigbee haven’t even been defined in the Matter specification yet, let alone implemented. That’s why I wouldn’t recommend going “all-in” on Matter just yet.
In my experience, the real “sweet spot” is a hybrid approach: using a mix of technologies like Zigbee, Wi-Fi, and Thread, while running multiple ecosystems (such as Aqara Home, Apple Home, and Home Assistant) in parallel. These platforms can be cross-integrated beautifully; Matter bridging for Zigbee devices and Aqara’s Advanced Matter Bridging are prime examples of this synergy.
The standout advantage of using Home Assistant is its ability to integrate closed systems, like the Ring Intercom, holiday lighting, or even car APIs. Whenever a system doesn’t support Matter, Home Assistant usually steps in. The sheer volume of community-driven integrations is impressive and shows the incredible power of the people behind it.
Of course, you could stick to a single ecosystem, but you’d have to live with the limitations. Restricting yourself to one platform significantly narrows your choice of hardware.
I’ve successfully integrated all my Matter devices into Apple Home, Aqara, and Home Assistant simultaneously without any stability issues.
There could be several reasons for the instability you’re seeing. I’d recommend checking out my guide for some deeper troubleshooting: Matter & Thread: A Guide Through the Jungle
I would specifically look at the section “Matter Pairing of Devices” → “Connecting to Additional Systems (Multi-Admin)” and the part covering “Link-Local vs. GUA vs. ULA.”
