I see this as either a battery quality issue (what brand are you using, and how old are they) or something keeping the P2 awake (config issue with your hub or a defect).
What would keep them awake? It’s paired to Apple and HA - but no automations or anything are configured. We’re not even touching the thing.
It sits in our bedroom - where we plan to install it - all of 4 feet away from the primary Apple TV for the house. So, it’s matter connection must be very strong given the distance.
Yeah, I’ve seen similar reports; especially when using the P2 with both HomeKit and Home Assistant via Matter. It seems like it might be over-communicating or getting stuck in some high-power state.
hmm. might be slightly different but my U200 door lock is battery operated and connected to both systems over Matter - it’s battery is good. Degradation is fairly slow - need to change the lock battery every ~4 months. Haven’t had to change the keypad battery at all.
Plus, it’s much further away from the main hub. Arguably, it has the lowest reception point in the house.
Only thing that comes to mind for me is that it’s constantly connecting/disconnecting possibly due to weak signal, can you move it closer to your hub/dongle?
Does home assistant offer any clues as to what might be going on when you look at the Logbook for the entity?
Coincidentally - I’ve disconnected it and reconnected it several times. In between fresh batteries it doesn’t connect - so I reset it and reconnect it.
No - HA just gives me the battery status. It goes from 100% to 50% within hours, then drops to ~25% a few days later, then quickly drops to 0 within 24 hours of hitting 25%. I have the history of it doing this pattern twice
You could also check that if you are usign something like home assistant etc that its not making 50 billion calls per sec to it or something. its rare but it does happen and it will nail the battery.
I have experienced this issue with one of my P2 motion sensors. In fact, this same sensor developed another issue where motion is always detected even when there is motion. At the end of the day, I threw it away.
