Presence Multi-sensor FP300 Tips: Boost Detection Accuracy šŸŽÆ
Millimeter-wave radar is what makes the Aqara FP300 a standout presence sensor – it detects even subtle movements like breathing, keeping your smart home automations on point. But nailing the setup and understanding its quirks is key. If you’re dealing with ā€œghost detections,ā€ missed presence alerts, or the sensor refusing to switch to ā€œabsenceā€, we’ve got you covered. These targeted fixes will help your FP300 perform like a pro!
Let’s dive into the most common issues and how to solve them – step by step, no tech jargon required! :blush:
1. Issue: ā€œSomeone is present, but the sensor says ā€˜no oneā€™ā€ / Can’t detect static people
If the FP300 fails to recognize you when you’re sitting still (e.g., working at a desk or resting) or incorrectly reports an empty room, try these fixes:
  • Let the device learn its environment :brain:: New devices or sensors moved to a new spot need ~10 minutes of ā€œquiet timeā€ (no one in the area) to finish spatial learning. Want to speed it up? Go to Zigbee mode’s ā€œOn-site configurationā€ and run ā€œAI Spatial Background Learning.ā€
  • Optimize installation position :pushpin:: Ensure the sensor has a clear line of sight – no obstacles in front. Aim it directly at the main activity area (e.g., sofa, bed, desk) for the best coverage.
  • Adjust the absence delay timer :hourglass_flowing_sand:: Lengthen the ā€œAbsence Delay Timerā€ (cool-down period) in settings. This gives the sensor more time to confirm the room is empty before switching to ā€œno one.ā€
  • Match sensitivity to your scene :gear:: Higher sensitivity = better at detecting static people. Choose based on how long you stay in the area:
    • Low: Bathrooms, hallways (stay <20 mins)
    • Medium: Studies, living rooms (daily use)
    • High: Bedrooms (stay >8 hours, e.g., sleeping)
2. Issue: ā€œNo one is here, but the sensor still says ā€˜someoneā€™ā€ (False alerts)
False ā€œsomeone presentā€ alerts are usually caused by interference or misconfigured settings – here’s how to fix them:
  • If it’s ā€œInfrared Motion Detectedā€ false alerts :fire:: PIR sensors are sensitive to temperature changes. Use the ā€œPresence/No Presenceā€ status (not ā€œInfrared Motion Detectedā€) as your automation trigger – it’s far more reliable.
  • If it’s radar false alerts (dual presence mode) :satellite::
    1. Customize detection range: In Zigbee mode’s ā€œOn-side Configuration,ā€ set a specific detection distance to exclude non-target areas (e.g., avoid triggering from a curtain or a fan).
    2. Lower sensitivity: Less sensitivity = stronger anti-interference. Follow the same scene-based guide above (low for short stays, high for long stays).
3. Issue: ā€œI left the room, but the sensor won’t switch to ā€˜no oneā€™ā€
Stuck on ā€œsomeone presentā€ even after you’ve left? Try these troubleshooting steps:
  • Update firmware first :rocket:: Outdated firmware can cause glitches. Make sure your FP300 is running the latest version – check in the Aqara app.
  • Refine detection range :dart:: Use Zigbee mode’s ā€œOn-side Configurationā€ to narrow the detection distance. This prevents the sensor from picking up movement outside your target area.
  • Re-run spatial learning :arrows_counterclockwise:: Go to ā€œOn-side Configurationā€ and execute "AI Spatial Background Learning again. Ensure the room is empty during this process so the sensor re-learns the ā€œemptyā€ environment.
  • Adjust sensitivity :gear:: Refer to the scene-based sensitivity guide above – lowering it can reduce interference from non-human movement.
  • Be patient with interference sources :window:: Moving curtains, swaying ceiling lights, or air flow can mimic subtle human movement. Give the sensor a few minutes to adapt – it will learn to distinguish interference over time.
Pro Tip for All Issues: Test After Adjustments! :white_check_mark:
After tweaking settings or repositioning the sensor, do a quick test: Walk in, sit still, then leave the room. Check if the sensor switches between ā€œsomeoneā€ and ā€œno oneā€ correctly. Small adjustments (like minor angle changes or sensitivity tweaks) can make a big difference!
With these fixes, your Aqara FP300 will deliver the precise, reliable detection it’s known for. If you still have questions, drop a comment below - the community are always here to help! :raised_hands:
#AqaraFP300 #DetectionTips #SmartHomeHacks #TroubleshootingGuide
FP300 and Thread is still not working so this post is kind of pointless.
Sensor is still completely useless in Thread mode on Home Assistant, Homekit, and Aqara app. Just always gets stuck on presence.
Could small animals affect it, such as mosquitoes? Because when it was running in a clean environment, it worked fine in Zigbee mode with Z2M. But when it was installed in a room where mosquitoes may be present, this issue started to appear.
I’ve been running it in ZHA with a custom quirk, it runs really well minus the missing LUX. Can trigger AI spacial and I haven’t gotten that dreaded hang on presence yet.
Using the FP300 without an Aqara hub. Home Assistant with a ZBT-2 (firmware OpenThread RCP 2.7.2.0) on Thread.
None of the tips worked, which I could perform on Thread.
I remembered reading somewhere that the ā€˜Hold’ time which was changed from 10 to something else was one was to ā€œfixā€ this. So I set this back to 10s and moments later the two FP300 which were stuck in Detected changed to clear (no presence).
Something definitely needs to be looked at. As I changed nothing in those rooms.
would you know if there is a way to downgrade from 0.0.0_5841 to 0.0.0_5234 ? I tried to find a copy of the firmware but can’t find it anywhere.
I have 2 of those I bought in november running 0.0.0_5234 wich runs perfectly well for me but just received 2 new ones with 0.0.0_5841 wich creates false positive every now and then, this is really anoying
I’m using mine in HA with the ZBT-1… I have the ZBT-2 for Zigbee so I’m very happy with my thread on the ZBT-1 and the FP300 is running perfectly.
