Hi there, here is a short screen recording hopefully highlighting what you need to see. If you want me to go into more detail then I can do.
Nice β¦
Trying to figure out how/why I would use this. . .
A couple of examples of how this could be used.
- If you have children, you will know that they often have a habit of leaving lights on. This come eliminate the problem as you can set it to turn the lights off when everyone has left the room.
- You can use it to automate when the heating turns on and off.
- You can use it to warn you if the humidity gets too high or too low and you need to turn a humidifier on or off.
- You can use it in a security automation so that if it detects movement when you are away from home then it can trigger alarms and light flashes.
These are just for examples. There are endless possibilities of the automations and scenes you can trigger with this one sensor. It not only has mmWave and PIR, but a light sensor, temperature sensor and humidity sensor all rolled into one package.
Perfect! Thank you.
This looks amazing. I can use it for so many things. Well done.
Wow, a must have gadget for smart home
Looks great!
Thanks, does it work with Apple Home?
Canβt wait for it to be available. I have several applications where I could use.
It does indeed! You can add it in the Aqara app in ZigBee and then connect it to Apple Home, or you can switch protocols to Thread and add it directly to the Apple Home, or any smart home app of your choice. This includes platforms like Home Assistant and HomeBridge.
Awesome. What applications do you have in mind? Feel free to share as it might give others some great ideas ![]()
Thanks for sharing! ![]()
Does anyone know if this will work in Homey Pro 2023? And does it use zigbee or matter?
Will it be available in Norway? and will it work in Homey?
Hi there, it has both ZigBee and Thread/Matter and it should work with Homey. I did explain this in the little video attached. Also, I believe this will be released in all regions. @AqaraOfficial please correct me if I am wrong.
I was looking at a FP2 sensor but realized it only works in Homey through Homekit, If FP300 works with Homey then i definetly need that.
Also do you know anything of how much it could cost? In Norwegian currency?
It will work with Homey pro in matter mode.
I do have an Aqara Camera Hub G3 and a Aqara Hub M3. So that should work perfectly! Thanks!
