Some Aqara Sensors Appearing Twice in Apple Home
I just wondered if anyone else had experienced this when using Apple Home?
I have a few different Aqara Sensors:
Aqara Smart Hub 100, Matter Controller, Thread Border Router
Aqara Thread/Zigbee Smart Climate Sensor W100
Aqara Temperature and Humidity Sensor
Aqara LED Strip, Matter over Bridge,
Aqara 4MP Camera Hub G5 Pro, PoE
I am mainly using Apple HomeKit with a HomePod acting as my Home Hub. I remember it all being a pig to set up, as some of the devices are matter over thread, some are Zigbee some were in range some were not.
Anyway, long story short - I managed to get it set up all working as I wanted. However I noticed that my Aquara LED strip light seems to appear as ‘Aqara LED’ and ‘Lightbulb’ in my Office setup, even though I only have one device. I can’t remember whether you had to set it up with the Aquara app first, and then add it to Apple Home, or the other way around. Either way it seems to appear twice - so don’t know if it is possible for it to be connected to my Apple Home Hub (aka HomePod) and my Aqara Smart Hub 100 at the same time?
The same thing seems to happen with my Aqara Climate sensor - this seems to appear twice in Apple Home. It seems you have to set it all up with the Aqara app first and then add it to Apple Home.
Basically I don’t know how to remove one instance of each of these devices without screwing everything up?
It seems Aqara want you to use their eco system, but many people (including myself) bought these devices so they could integrate nicely into Apple Home.
Any advice appreciated!
Check this out. Maybe it’ll help you.
Thanks for this detailed explanation. I just looked under Home Settings in Apple Home, and then ‘Home Hubs & Bridges’. It looked like the Aqara Hub M100 had been added twice. One had a device ‘Aqara LED Strip T1’ and the other other hub had a device called ‘Lightbulb’ - but they were both pointing to the same LED strip. So I just chose to remove the Aqara hub that had the ‘Lightbulb’ accessory connected. As soon as I removed that hub from Apple home my duplicated sensors disappeared.
I vaguely remember I had problems pairing it the first time when I first tried to set it up, so I had to set it up again. It had obviously been added twice somehow without me realising. I think it’s sorted now. Thanks for your help!
