Switch on Carport Lights with P1
Greetings,
I use a P1 in combination with a Aqara smart plug to switch on the carport lights and witch them off again, if no movement is detected for longer than 1min.
My solution currently are two automations:
  1. P1 - if movement is detected switch the smart plug on
  2. P1 - if no movement is detected for longer than 1 min switch the smart plug off
It works but I was wondering if this is the best solution or if the community would suggest a different approach - like using the delay functionality in the automations - or if I should add another automation which notifies, if the smart plug is switched on for longer than 5min to avoid that the lights are burning for too long.
Thanks for your feedback.
Cheers
Janis
Hello, I cover these topics extensively in my lessons 5,6, review them and many of your questions will disappear. If you need help, I’m always happy to help, write under the lesson where you have questions. Automation 2.0, Lesson 5, vector lighting control by sensors
