The Aqara M3 Hub Guide
Here is my guide for the M3 Hub. As usual I have included the PDF if you want it for your records, or if you think it can help someone, then you can pass it along.
Aqara M3 Guide.pdf (250.2 KB)
Aqara Smart Home Info Sheet Series
Aqara Hub M3 Guide
A multi protocol, privacy focused smart home hub that delivers powerful local automation, Matter bridging and advanced infrared device control.
Overview
The Aqara Hub M3 is Aqara’s most advanced smart home hub. It is designed to prioritise local control, privacy and reliability.
The hub acts as a multi protocol bridge. It supports Aqara Zigbee and Thread devices, while also exposing them to platforms such as Apple Home, Google Home and Amazon Alexa through Matter.
Unlike earlier Aqara hubs, the M3 focuses heavily on edge computing. This allows many automations to run locally on the hub instead of relying on cloud processing.
This provides several advantages.
β€’ Faster automation response
β€’ Greater reliability
β€’ Reduced dependence on internet connectivity
β€’ Improved data privacy
Many automations will continue to function even when the internet connection is unavailable.
Usage & Reliability
The Hub M3 is designed for stable and scalable smart home installations.
Key capabilities include:
β€’ Aqara Zigbee device support
β€’ Aqara Thread device support
β€’ Matter bridge for Aqara accessories
β€’ Integration of compatible third party Matter devices
β€’ Local execution of most automations
β€’ Dual band Wi Fi support at 2.4 GHz and 5 GHz
β€’ Ethernet RJ45 connectivity
β€’ Power over Ethernet support
β€’ USB C power input
β€’ Built in infrared controller with learning capability
β€’ No microphones or cameras
β€’ Encrypted local storage with 8GB eMMC
Cloud Dependencies
Although many automations run locally, some features require cloud access.
These include:
β€’ Push notifications
β€’ Weather conditions
β€’ Sunrise and sunset triggers
β€’ Geofencing automations
  • Remote access outside the home network
Main Features
1. Multi Protocol Hub with Matter Support
The Hub M3 acts as a central bridge between Aqara devices and the wider Matter ecosystem.
It can perform the following tasks:
β€’ Connect Aqara Zigbee devices
β€’ Connect Aqara Thread devices
β€’ Bridge Aqara accessories to Matter platforms
β€’ Integrate compatible third party Matter devices into Aqara Home
Third party Matter compatibility was limited at launch but continues to expand as the Matter ecosystem develops.
This approach reduces protocol complexity while allowing greater platform flexibility.
2. Edge Computing and Local Automation
The M3 moves much of the automation processing from the cloud to the hub itself.
This provides several benefits.
β€’ Faster automation execution
β€’ Improved reliability
β€’ Reduced reliance on internet connectivity
β€’ Enhanced privacy
Many everyday automations such as sensor triggers, lighting control and infrared appliance control can continue working even if the internet connection is lost.
3. Infrared Controller Integration
The Hub M3 includes a 360 degree infrared controller with command learning and state feedback capabilities.
This allows the hub to control traditional infrared appliances including:
β€’ Air conditioners
β€’ Televisions
β€’ Fans
β€’ Projectors
β€’ Audio equipment
Features include:
β€’ Learning commands from existing remote controls
β€’ Automated infrared device control
β€’ Feedback for supported air conditioner protocols
β€’ Exposure of infrared devices to smart home platforms
When paired with Aqara temperature sensors, air conditioners can behave similarly to smart thermostats and can be controlled automatically based on room conditions.
4. Flexible Wired and Wireless Connectivity
The M3 offers multiple connectivity options for different installation environments.
β€’ Dual band Wi Fi for flexible placement
β€’ Ethernet RJ45 for wired stability
β€’ Power over Ethernet for single cable installation
These options allow installation in locations such as:
β€’ Network cabinets
β€’ Ceilings
β€’ Wall mounts
β€’ Desktops or shelves
5. Privacy Focused Design
Privacy is a core design principle of the Hub M3.
The device includes:
β€’ No microphones
β€’ No cameras
β€’ Local processing of automation logic
This allows advanced automation without unnecessary cloud based data processing.
6. Hub Replacement and Migration
The M3 can replace older Aqara hubs.
This allows users to:
β€’ Designate the M3 as the primary hub
β€’ Migrate Zigbee devices from older hubs
β€’ Improve local automation performance
Some automations and scenes may need to be recreated after migration, especially those exposed through Matter or Apple Home.
Cloud integrations such as Google Home and Alexa usually retain most existing configurations.
7. Built In Speaker for Alerts and Announcements
The Hub M3 includes a built in speaker.
It can be used for:
β€’ Aqara security alarm sounds
β€’ Custom alert tones
β€’ Audible notifications
β€’ Event announcements
Because automation processing occurs locally, these alerts can still function even if the internet connection is unavailable.
Accessibility & Ease of Use
The Hub M3 supports accessibility-focused smart home setups.
For mobility limitations:
β€’ Fully automated routines
β€’ Reduced need for physical interaction
β€’ Reliable local execution
For visual impairment:
β€’ Audible alerts and alarms
β€’ Voice-assistant-driven control
β€’ Clear feedback through sound
For cognitive or memory challenges:
β€’ Predictable automation behaviour
β€’ Reduced reliance on manual control
β€’ Local execution improves consistency
Practical Scenarios
Scenario Use Case Example
Central Hub Whole-home control All sensors β†’ Local automations
Energy Saving Presence-based HVAC Absence β†’ Thermostat eco mode
Smart AC Control IR + sensor Temp rises β†’ AC adjusts
Lighting Automation Motion + lux Motion + <100 lux β†’ Lights on
Privacy-Focused Setup Local execution Automations run offline
Migration Upgrade Hub replacement Old hub β†’ M3 lead hub
Matter Bridge Cross-platform control Aqara devices β†’ Apple Home
Wired Reliability Network cabinet install Ethernet + PoE
Audible Alerts Security feedback Alarm β†’ Hub siren
Announcements Status feedback Event β†’ Custom sound
Aqara Home Automations
Automations created inside the Aqara Home app can run locally on the hub. This provides faster response times and greater reliability.
Energy Saving HVAC Automation Step by Step
  1. Open the Aqara Home app.
  2. Tap the + icon in the top right corner.
  3. Tap Automation.
  4. Under WHEN choose:
Accessories β†’ Presence Sensor FP2 β†’ Absence detected
  1. Under IF choose:
Accessories β†’ Temperature Sensor β†’ Temperature above set point
  1. Under THEN choose:
Accessories β†’ IR Air Conditioner β†’ Set to energy saving mode
  1. Save the automation.
The air conditioner will switch to energy saving mode when the room is empty and the temperature exceeds the chosen value.
Motion and Brightness Lighting Automation
  1. Open Automation in the Aqara Home app.
  2. Under WHEN choose:
Accessories β†’ Motion Sensor β†’ Motion detected
  1. Under IF choose:
Weather or Environment β†’ Illuminance β†’ Less than 100 lux
Accessories β†’ Ceiling Light β†’ Turn on
  1. Set colour temperature to cool white.
  2. Save the automation.
Lights will now turn on automatically when motion is detected in low light conditions.
Audible Alert Automation
  1. Open Automation.
Accessories β†’ Door Sensor β†’ Opened
Accessories β†’ Hub M3 β†’ Play alert sound
The hub will play an audible alert when the door opens.
Apple Home Automations
When the Hub M3 is connected to Apple Home using Matter, devices connected to the hub appear as standard Home accessories.
Examples include:
β€’ Thermostats for infrared controlled air conditioners
β€’ Lights and switches
β€’ Motion and contact sensors
β€’ Temperature and humidity sensors
These devices can then be used in Apple Home scenes and automations alongside other HomeKit or Matter devices.
Example Automation
Scheduled Air Conditioner Cooling
  1. Open the Apple Home app.
  2. Tap the + icon.
  3. Tap Add Automation.
  4. Select A Time of Day Occurs.
  5. Choose the time you want the automation to run. (Example: 7:00 PM)
  6. Tap Next.
  7. Select the Air Conditioner accessory that appears through the Hub M3.
  8. Configure the settings.
Power: On
Mode: Cool
Temperature: 22 degrees Celsius
  1. Tap Done.
The air conditioner will now automatically start cooling at the scheduled time.
Example Automation
Turn Off AC When Everyone Leaves
  1. Open the Home app.
  2. Tap the + icon.
  4. Select When the Last Person Leaves Home.
  5. Tap Next.
  6. Select the Air Conditioner accessory.
  7. Set Power to Off.
  8. Tap Done.
The air conditioner will turn off automatically when the home becomes empty.
How Matter Integration Works
When using the Aqara Hub M3 with Apple Home, the automation process follows this sequence.
Apple Home automation runs
The command is sent to the Hub M3 using Matter
The hub processes the request locally
The hub sends an infrared signal to the appliance
The appliance responds
This allows traditional infrared appliances to behave like smart devices within Apple Home.
Tips for Best Use
For the best experience:
β€’ Use Ethernet or Power over Ethernet when possible
β€’ Place the hub where its infrared signal can reach appliances clearly
β€’ Pair Zigbee devices close to the hub during setup
β€’ Plan hub migration before switching the lead hub
β€’ Use local automations whenever possible
β€’ Combine presence sensors and temperature sensors for HVAC control
β€’ Keep firmware up to date
  • Use the built in speaker for audible alerts
Final Thought
The Aqara Hub M3 represents a significant step forward for the Aqara smart home ecosystem.
By prioritising local automation, privacy focused design and multi protocol Matter integration, the hub provides a strong foundation for both current and future smart home setups.
For users building a reliable and scalable smart home that works across multiple platforms, the Hub M3 stands out as Aqara’s most capable hub to date.
Thanks for sharing!
Hello, @UKAndyC.
Thank you very much for such a detailed description of the M3’s capabilities. I want to continue your description by adding a link to the virtual IR remote control that you mentioned in the description.
