Turn Your Smart Home into an “Energy Manager” With Aqara Smart Thermostat W200
Most people don’t waste energy on purpose… we just forget.
Lights get left on.
Thermostats run when nobody’s home.
Devices quietly draw power 24/7.
So instead of trying to remember everything, I started thinking about my smart home differently:
:point_right: What if it had one primary job?
Don’t waste energy.
The Simple Framework
I’ve been approaching this with three basic rules:
  1. Don’t power empty rooms
  2. Don’t heat or cool an empty house
  3. Don’t feed devices that aren’t being used
When your smart home follows those rules consistently, the savings start to add up, without you having to think about it.
So, how can Aqara help you do this?
Lighting: Fixing the Most Common Waste
Lighting isn’t the biggest energy cost, but it’s the easiest place to waste energy.
Start with Smart Switches Like the H2 or the new S100 or T2 Light Bulbs in locations that make sense.
Then, using presence detection (like the FP300), you can make lighting automatic:
  • Walk in → lights on
  • Leave → lights off
The key difference with presence vs motion is that the system knows you’re still in the room even if you’re sitting still.
So lights don’t shut off unexpectedly, but they also don’t stay on by accident.
Standby Power: The Hidden Drain
Then there’s standby power: stuff you don’t see like TVs, consoles, office equipment, chargers… Things that draw power even if they are off.
Individually small, but always on.
Using smart plugs, you can cut power to these devices when they’re not needed:
  • Turn off media centers overnight
  • Shut down office setups after work hours
  • Eliminate constant background draw
It’s not about micromanaging outlets — it’s about removing waste automatically. You can pick up an existing Aqara smart plug today, but at CES they showcased a new smart plug that is itself focused on minimal standby power draw. The key is that the smart plug must draw less energy than what’s plugged into it.
HVAC: The Biggest Impact
For most homes, HVAC is the biggest energy user, often 40–50% of total consumption.
This is where things get more impactful.
With something like the Aqara W200 thermostat, the goal isn’t just scheduling — it’s context-aware control.
For example:
  • When the home is empty → shift to eco mode
  • When someone returns → restore comfort
  • If a door or window is left open (maybe even paired with the new P100) → pause heating/cooling
That last one alone prevents a surprising amount of waste in real homes.
The W200 is way more than just a standard thermostat (as you’ll see from any of the reviews you read), but with the ability to dynamically pair sensors and the use of Apple’s Adaptive Temperature, it can certainly do the job of optimizing your HVAC incredibly well. Instead of running on a rigid schedule, the system responds to what’s actually happening.
Everything Else
And then there’s everything else — water heating, appliances, and the loads that don’t fit neatly into one category.
Some of those you want to optimize.
Some you want to leave alone.
That’s where whole-home energy monitoring becomes really interesting — actually seeing where power is going instead of guessing. With Aqara’s push into the Pro and industrial Market, we should see whole home energy solutions from them soon.
Where It All Comes Together: Automations
Individually, these things don’t seem like much.
But when you tie them together with automations, the system becomes consistent.
No reminders.
No manual control.
It just happens.
Aqara’s focus on Spatial Intelligence with standalone sensors like FP300 and mmWave built-in to products like switches (S100) and thermostats (W200), give them a unique edge at building a seamless experience for energy efficiency. It’s time to not just think of these smart home devices as novel tech to enjoy, but give it the important job of saving us energy.
Curious how others are approaching this:
:point_right: Where do you see the most energy waste in your home?
:point_right: Are you focusing more on HVAC, lighting, or plug loads?
Great article and video! I was fortunate enough to get the W200 thermostat early and we are loving it! We had an older Honeywell before and we’ve already seen a dip in our power usage. Because you are 100% right there’s no need for the furnace to heat up the whole house when we are both gone for the day!
