Hi everyone. I followed @gafich10 tutorial to change the temperature setting in custom mode. Since then, the W100 has been regularly connected to E1 without any association errors. So, I switched from standard mode to custom mode. I no longer see any log issues on E1. Before that modification, I often had a “connection error” with the E1 valve. Now, however, I don’t.
In practice, the settings to modify on the W100 device are as follows:
Set:
Temperature and humidity sampling settings from standard to custom.
Under Custom Calibration:
Sampling period > 10 minutes
In the Temperature section
Reporting mode >
Threshold and period
Period > 10 min
Threshold > 0.5 °C
In the Humidity section
Reporting mode > Period
Period > 10 min
I hope this can clarify and help anyone who has had connection problems like me.
Thanks.
Also if you are interested this is the original post regarding this problem.
