UWB on the u400 hasn’t worked for me since I got the lock.
I have an iPhone 16 Pro Max on the latest iOS, pairing it with the mini HomePod for the hub.
The cable is connected properly, but UWB doesn’t work.
Not sure if you’ve reviewed it yet or not, but the pairing guide here is very good: Aqara Smart Lock U400 Pairing Guide
Me, in order to get the Matter connection to work, I had to disable the 5GHz Wifi radios in my Nokia WAP. I also switched my Apple TV from Ethernet to Wifi, just to ensure that interface was live. (that’s just for the initial setup).
I’m in the exact same boat.
My Tap to Unlock works, but for the life of me I can’t get UWB to work. Additionally, after I set up the two U400 locks in Apple Home, I can’t add them to the Aqara app. The app’s bluetooth connection doesn’t find them, even though I can see the locks using the BT Inspector app.
Both my phone’s Wallet and watch’s Wallet apps have Unlock on Approach enabled.
The UWB indicator light on the keypad doesn’t light up…ever. The next step I might try is Resetting the locks…but then we lose the PIN codes and fingerprints that my wife and I set up. Not even sure that will fix it.
I’ve opened a ticket, but interested to learn if you’ve found a solution yet.
Replying to myself…
I ended up removing the lock from all ecosystems (Apple Home, Home Assistant, UniFi). I then reset the lock.
Afterwards, the Aqara app immediately found it via Bluetooth and I scanned the top code to add it. Afterwards, I scanned the matter code using the Home app and added it there.
Now that I had the lock in both ecosystems, I tried UWB again and it still doesn’t work. I have to imagine this is a firmware issue that needs to get resolved by Aqara. It also confirms that the recommended setup guide is wrong/outdated because the Aqara app refuses to connect to the lock via Bluetooth is the lock has already been paired with Apple Home via Matter.
