W600: motor runs but the pin does not move — 2 units out of the box, now a 3rd after 2 weeks
I like the W600 and was happy using it, so I’m sorry to have to report this.
Short version: two of my W600s had this fault straight out of the box — the motor ran non-stop and the pin never moved, before the units had been used at all. Both went back to the seller. Now a third unit has developed exactly the same fault after two weeks. Since two units were already like this when new, I don’t believe this has anything to do with how the valve is used.
Setup: W600 on Zigbee, Hub M3, firmware 0.0.0_2848.
What happened with the third unit
  • The unit worked normally for two weeks: it opened and closed on command and reported its valve position.
  • Then, from one moment to the next, it stopped responding mechanically. The last thing it did was follow a few ordinary setpoint changes (open → close → open within about two minutes).
  • The motor runs, but the pin (plunger) does not move.
  • The reported valve position has been frozen at 100 % since then. The unit is still online, still reports its temperature and still accepts setpoint changes — only the mechanical movement and the position report are missing.
  • Valve calibration from the app never finishes. With the unit taken off the radiator: F1 → press 3× → F2, the motor keeps running and the plunger does not move.
  • There is no physical damage. The unit was mounted on the radiator in a protected corner of the room.
What I tried: repeating the close command many times, setting 30 °C manually in the Aqara app, valve calibration from the app, removing and re-adding the device, starting the calibration by hand off the radiator. Nothing changed.
Why I’m posting
Three units with the identical symptom — two of them brand new — looks like a hardware weakness to me, not a one-off. I still have two more W600s in daily use and I’m worried they will go the same way. An E1 on the same hub has been working without problems.
Questions
  1. Has anyone else had a W600 fail like this after days or weeks of normal use — motor audible, pin not moving?
  2. @AqaraOfficial — is this a known mechanical issue (gear or coupling between motor and plunger)?
  3. Is there anything left to try besides replacing the unit?
Possibly related: W600 killing itself in the middle of the night and stuck on “F2” calibration loop.
