Welcome to Everything Matter - Embracing Interoperability
Welcome to the Everything Matter category! This is where we explore the transformative potential of the Matter protocol in the smart home industry. Aqara is excited to lead the charge by continuously introducing a variety of Matter-supported devices and fully integrating third-party Matter devices into the Aqara Home ecosystem. Our goal is to provide Smart Home users with easy and smooth interoperability, bridging the gap between devices and creating a truly interconnected smart home experience.
:triangular_flag_on_post: Topics for Discussion:
:rocket: Device Compatibility: Share experiences and solutions regarding the integration of Aqara and third-party Matter devices into your smart home setup.
:rocket: Functional Enhancements: Discuss how Matter enhances the functionality and user experience of your smart home devices.
:rocket: Industry Trends: Stay updated on the latest developments and innovations in the smart home industry, driven by Matter.
:triangular_flag_on_post: Community Guidelines:
:rocket: Respectful Interaction: Maintain a courteous and inclusive tone in all discussions.
:rocket: Stay Focused: Keep conversations centered on Matter-related topics to ensure meaningful interactions.
:rocket: Transparency: Share accurate and truthful information, avoiding any misleading claims.
:rocket: No Spam: Refrain from promoting unrelated products or services.
:rocket: Collaboration: Work together to foster a supportive and innovative environment.
:triangular_flag_on_post:Tips:
:rocket:Try to @AqaraBot in the post, and your AI friend in this community will come and answer your question to the best of its ability!
@AqaraOfficial Welcome to the vibrant world of the Matter protocol! :tada: As a tech enthusiast and a fan of Aqara, it’s fantastic to see you diving into discussions about how Matter is reshaping the smart home landscape. Aqara’s commitment to integrating both its own and third-party Matter devices truly paves the way for a seamless and interconnected smart home experience.
Let’s dive into the topics you’ve highlighted:
Integrating Aqara and third-party Matter devices can sometimes be a puzzle. It’s crucial to ensure your devices are Matter-certified and in pairing mode. If you’re having trouble, a good reset or firmware update might just be the trick you need to get everything running smoothly. Remember, the Aqara Home app is your friend here!
Matter is like the universal translator of the smart home world, allowing devices to communicate more effectively, regardless of their brand. This means you can create more complex automation scenes and enjoy a more intuitive user experience.
The smart home industry is buzzing with innovation, much of it driven by Matter. Keeping an eye on firmware updates and new device releases can keep you ahead of the curve.
Your community guidelines are spot-on for fostering a positive environment. Remember, if you ever need assistance, @AqaraBot is here to help!
Keep sharing your insights and experiences, and let’s continue to make the smart home ecosystem even smarter together! :bulb:
@AqaraBot that’s great, but how about compatibility between the Aqara P2 door and window sensor and the M3 hub, which is NOT a third-party matter device, but still doesn’t work?
@CheckingCzechCheques I understand you’re facing challenges with the compatibility between the Aqara Door and Window Sensor P2 and the M3 hub, even though it’s not a third-party Matter device. Here are some troubleshooting steps that may help you resolve this issue:
  1. Firmware and App Update: Ensure that both your Aqara hub (M3 or G5 pro) and the app are updated to the latest versions. This can often resolve compatibility issues.
  2. Network Check: Confirm that both the Aqara Thread Hub and your phone are connected to the same local area network. Also, make sure your router supports IPv6, as this is necessary for adding Matter devices. A quick router restart might help too.
  3. Distance and Signal: The sensor might be too far from the hub. Try moving it closer to verify if the connection improves. The distance between the sensor and the router should ideally be less than 22 mm for optimal performance.
  4. Reset and Reconnect: If these steps don’t work, try resetting the sensor by pressing the button quickly ten times until the indicator flashes. Then, attempt to reconnect the sensor to the hub.
If these suggestions don’t solve the issue, it could be worth creating a new thread network for the hub and binding the sensor again.
Feel free to share your experiences or any further questions. The community here is eager to help each other out!
@AqaraBot I’ve done ALL of that, and it still doesn’t work.
What specific network features need to be enabled for the P2 door and window sensor to pair over matter? Are there any known issues between these two devices that stop them from working together?
@CheckingCzechCheques I’m sorry to hear that you’re having trouble with your P2 door and window sensor. The Aqara Door and Window Sensor P2 is integrated into the Matter ecosystem, which requires certain network features for proper pairing. Based on the reference information, here are some key points to ensure successful pairing:
  1. Network Compatibility: Make sure your router supports iPV6, as Matter devices require this for connectivity. If iPV6 is not enabled, you may need to turn it on and then restart your network devices.
  2. Same Local Network: Ensure that both your Aqara Thread Hub and your phone are connected to the same local area network.
  3. Update Firmware and App: Confirm that the firmware version of your Aqara hub matter controller and the app version are updated to the latest versions (M3 or G5 pro).
  4. Distance Consideration: The sensor should be positioned reasonably close to the border router. If the sensor is too far, try bringing it closer and then attempt to re-bind the device.
  5. Reset and Reconnect: If issues persist, try restarting the hub and reinstalling the battery in the sensor. You might also consider creating a new thread network for the hub and re-binding it.
If these steps do not resolve the issue, there could be specific compatibility issues between your devices. In this case, I recommend reaching out to the Aqara community for additional insights or contacting customer support for further assistance. Feel free to share any additional details or questions you might have; the community and I are here to help!
@CheckingCzechCheques I face no issues adding P2 door and window sensors to my M3 hub using the Matter QR-code which is printed in the provided paperwork.
My environment is as follows:
  • Router which offers IPv4 and IPv6 IP addressen to all DHCP clients; IPv6 is important for Matter/Thread devices
  • Aqara Hub M3 w/ latest firmware
  • latest Aqara Home app
@memseeker my network is the same, ipv6 via DHCP, latest firmware on m3, latest app…
Everything just gets stuck at step 3/4 for the matter setup. I’ve checked network connectivity and comms via Wireshark, which all appears normal…, no issues with ipv6 connectivity.
It looks like the same issue which we discussed in the following thread, Unable to add T2 Bulbs to M3 via Thread & Aqara Response - #2 by AqaraBot
@Nicholas.Aqara thanks for the reply - I’m purely running android and just the aqara m3 as the only thread router in the house.
I finally got it working, not sure if it was a firmware update, my changes in network config, or both… But here’s what I did after the latest updates…
  1. make sure you’re not using VPN on your mobile devices, or on your router, Aqara doesn’t like it. Devices will NOT add or get past step 3 with VPN (I had tried this previously, but this alone didn’t fix the issue)
  2. I had my ipv6 IP range set in DHCP to be in the fe80::/64 range. This didn’t work.
  3. after seeing my android was being assigned ipv6 addresses (I assume from the aqara hub, definitely not my router) in the fd00::/8 range, I had an inkling as to where the issue may be.
  4. I set the DHCP range in my router (a unifi) to be in the fd00::/8 range, but in a separate /64 range from what aqara was assigning. It seems that being in a different /8 range (fe80::/64), albeit in the exact same network, was causing issues.
Now I’ve been able to get not only the P2 matter sensors working on my M3 hub, but also my third party Lifx matter enabled down lights too.
Does the G3 sensor support matter? How do I enable it?
I also have the G3 hooked up to my google home but the video won’t work on google home. Anyone know how to get this to work on the google home app?
I have a u200 lite smart lock connected via matter to my Homey Pro hub, they are located fairly close together separated by a thin wall. Now every now and then my homey loses connection with the lock.
I don’t know if it’s the lock or homey, the Apple TV seems less affected by this and keeps an connection more often, or at least it manages to recover the connection compared to homey.
Following your message. I just ordered U200 and I was wondering which route to go with connecting it directly via Thread to HomeyPro or buying an Aqara M100 and using the it’s native thread radio and then matter bridging it HomeyPro. I heard my thread connection would be better with the Aqara hub.
It does indeed appear to be more stable with the hub from what I’ve read.
Having the homey pro restart every night seems to mitigate the issue however
Matter if the future
It’s here right?
i want to expose h2 swit with matter to Ledvance smart+ … it work only for 2 switches… but not 4 buttons…
but want to use buton to tun on/off ledwance wifi light.
Cen maybe be done with HA?
I wonder why there is still the need for an Aqara Hub when using Matter devices. My sole explanation is that the Aqara Home App does not implement itself the Matter protocol. Why can I read data from Aqara Sensors in other Apps (e.g. Eve App), but not in the Aqara App? The irony of all this is that one cannot even add an Aqara Matter Sensor in the Aqara App, but the sensor can be successful added in e.g. Apple HomeKit without any Hub support! Are any plans to support Matter natively in the Aqara Home App? In my case, I have a W100 Sensor and I am happy with it, but I can’t configure specific parameters and/or perform firmware updates without having it in the Aqara Home App. And don’t tell me I need an Aqara hub, I refuse to buy “Yet Another Hub or Bridge”!
