Has anyone used the window/door sensor outside? What was your experience with it? Did you have any type of weatherproofing?
Hi. I have a temperature sensor set up outside that’s housed in a small box, and it works great.
The P100 Multi-State Sensor is also a window/door sensor, and I’ve read here from others that you can get silicone covers for it that are supposed to work outdoors.
Unfortunately, I can’t find that post right now, but I did find another post here that also addresses the topic:
There are also retailers (at least here in Germany) that sell the P100 with a waterproof cover: Aqara Multi-State Sensor P100 - inkl. wasserfester HĂĽlle kaufen | tink
You can already find waterproof 3D-printed cases. Just search for them:
https://3dgo.app/models/makerworld/2817583
You can also find waterproof housings for the Door and Window Sensor P2, for example on Etsy: https://www.etsy.com/listing/4354255624/aqara-waterproof-case-opening-sensor-for
Thanks for the info!
I got a 3D printed weather proof cover/mount off of Etsy. Works great. However, now I need to change the batteries and don’t want to unscrew it.
Perhaps you meant this one?
I think it was a different post. I remember there being a link to a silicone case in it. Thanks for trying anyway!
I 3d printed a case and have mounted one outside for some time with no issues.
I also have two sensors outside for years - one is in a dry place and the other one is covered by a 3d printed housing - it just works
I have been using an Aqara Door and Window Sensor in my outdoor mailbox for a couple of years now. The mailbox has a two-part lid: the sensor is attached to the inside of the inner lid, with the magnet attached to the inside of the outer lid.
I previously used an Aqara Vibration Sensor in the mailbox as well, and I still use a Vibration Sensor outdoors on my terrace. I also have an Aqara Temperature Sensor on the terrace.
All of these sensors have worked reliably year-round for several years. During the winter, temperatures here can drop as low as -25 °C. Despite the cold and possible exposure to moisture, I have had no issues with their operation.
They are outdoors and exposed to normal outdoor conditions, but rain and snow do not fall directly on the sensors.
Based on my experience, Aqara sensors can work surprisingly well outdoors, even though they are not officially designed for outdoor use.
This was the only critique of the many enclosures I’ve designed, but I recently updated my design so it uses keyholes to mount, so it’s pretty easy to pull the enclosure off if you’re mounting it using screws. There are still bolts keeping the enclosure sealed, though, but I wouldn’t trust anything less such as a press-fitting to maintain a good seal with the gasket and keep moisture out.
DM me a link?
I just finished up this weatherproof enclosure for the P100 and got the first few batches printed today. It’s a very similar to my other weatherproof sensor enclosures, which have been used thousands of times and I have yet to hear of any issues. I’ve had several of my enclosures in use outside through several wet summers and freezing winters in the northeastern US and they’ve held up great.
