Automation 2.0. Lesson 3. Controlling lighting devices
Lesson 1 Automation 2.0 Tutorial Collection - Lesson 1 report
Lesson 2 Automation 2.0. Lesson2. Advanced settings "..." (Execution time, delay of conditions, reversal of conditions) is
Good afternoon, today’s lesson is devoted to creating automations related to lighting control. Perhaps I will not surprise a certain group of readers with this lesson, but it will be useful for beginners.
Let’s consider the use of the following devices:
  • motion sensor;
  • door opening sensor;
  • contactless control button;
  • AqaraT1 lamp.
    Let’s create basic automations.
    1.1 If there is movement, then turn on the light.
    (I will once, in detail, show the creation process for “dummies” step by step, then I will give screenshots of ready-made automations with a description.)
    Open a new automation, in the WTEH section select the motion sensor->“there is movement”.
    Fig. 1,2,3,4.
In the “IF” section, select “Off lamp”. We use this parameter so that the automation does not spam constantly and does not trigger the lamp to turn on with each movement.
Fig5,6,7
In the TNE section, select the lamp->“On lamp”
Fig8,9,10,11.
1.2 If there is no movement (a certain period) then turn off the light.
Fig 12
That’s it, we have the simplest automation for On/Off light ready.
2.1 If the door is open, turn on the light.
Such automation is also of the simplest type. A feature of this automation is the addition of the “Off lamp” condition to the “IF” section, this condition is added so that the same trigger (door opening) controls both “On” and “Off” lamps.
Fig 13
2.2 If the door is open, then Off lamp.
Please note that in the “IF” conditions we changed the lamp state to “On lamp”, this is what I said, one command (opening) controls the turning off of the lighting lamp.
Fig. 14
  1. If you press the button once, then turn on the light (turn off the light).
    I will not describe it here, it is an analogue of the opening sensor.
    Fig. 15, 16.
We create group automation.
The next part of the lesson will be combining these automations into one automation. To reduce the number of automations, version 2.0 makes it possible to group a group of automations (up to 5-6 pieces) into one automation in 1.0.
4. Turning on (turning off) lamps from a group of conditions.
4.1. On groups of lamps.
Add to the “WTEN” condition all the above listed device conditions (button, motion sensor, opening sensor)
In the “IF” condition, add “OFF lamps”
In “TNE” we add “On lamps”
Fig. 17
4.2. Off groups of lamps.
Add to the “WTEN” condition the same as in 4.1. just change the motion sensor to the command “No movement for 5 minutes”.
In the “IF” condition, add “On lamps”
In “TNE” add “Off lamps”
Fig. 18
These are two ready-made automations that will perform On/Off lamps without time restrictions of the day.
In order not to overload the lesson, we will end it here.
In the next lesson 4, I will tell you how to organize lighting by time periods (day, evening, night, morning).
This is my know-how that I came up with for the versatility of lighting control in one automation, yes, this is not a typo, it is in one automation to start lamps by time periods.
See you in the next lesson 4.
Thank you for reading and sharing the topic (you can also on other platforms with a link to our forum).
Lesson 4 Automation 2.0. Lesson 4. Lighting control by time periods
@gafich10 Hello! It’s great to see your interest in setting up lighting automations with Aqara devices. Your detailed breakdown is incredibly helpful for beginners who are just starting their smart home journey. Using motion sensors, door opening sensors, and contactless control buttons for such automations is a fantastic way to introduce convenience and energy efficiency to any home.
Grouping automations to control multiple actions with fewer setups is a smart move and showcases the efficiency of automation 2.0. I’m excited for your next lesson on organizing lighting by time periods—it sounds like a valuable addition to any smart home setup. Keep up the great work, and thank you for sharing your knowledge with the community! Looking forward to lesson 4.
@gafich10 This is such a valuable share for beginners diving into Aqara lighting automations! Breaking down the process step-by-step—from motion-triggered on/off to grouping conditions—makes it easy to follow, and the screenshots are a great touch for visual learners. It’s clear you’ve put a lot of thought into making complex setups approachable, which will definitely help new users avoid common pitfalls like “spamming” automations.
Your upcoming lesson on time-period lighting control sounds intriguing too—organizing it all into one automation is a clever know-how, and I’m sure the community is looking forward to it. Thanks for taking the time to share your expertise and contribute to the forum; resources like these make the Aqara ecosystem more accessible for everyone. Keep up the great work, and we’ll be here for Lesson 4!
P.S. For anyone who tries these automations, feel free to share your experiences or questions in the comments—collaboration makes these tutorials even stronger!
@gafich10 Good afternoon! Thank you for sharing this comprehensive guide on creating lighting automation using Aqara devices. It’s a fantastic resource for beginners looking to get started with smart home automation. Your step-by-step instructions and visual aids make it easy to follow along, and I appreciate the way you’ve broken down the process into clear sections. Grouping multiple automations into one is a helpful tip to streamline smart home setups.
Looking forward to your next lesson on organizing lighting by time periods. It’s great to see how you’re making smart lighting even more versatile and efficient. Keep up the great work, and thank you for contributing to the community! If anyone has questions or needs further clarification, feel free to ask.
@gafich10 This is a fantastic and detailed lesson on creating lighting automations—perfect for beginners who are just starting to explore Aqara’s automation capabilities! Breaking down the process step-by-step with clear examples (like motion sensors, door sensors, and button controls) and including screenshots makes it easy to follow, which is incredibly helpful. Grouping automations to reduce clutter is a smart tip too.
Thank you for taking the time to share your knowledge and “know-how” with the community—resources like this help make smart home setups more accessible to everyone. We’re all looking forward to Lesson 4 on time-period lighting control! Keep up the great work, and feel free to share more tips or insights in the future. :blush:
It’s okay, I’ll continue.
I’m writing this for the bot to remove unread posts from the forum :rofl:
@gafich10 Glad to hear you’ll keep sharing these practical automation lessons! Your step-by-step guides are incredibly helpful for beginners getting to grips with Aqara’s features—truly a valuable contribution to the community. It’s awesome to see your dedication, and we’re all excited for Lesson 4 on time-period lighting control. Keep up the great work, and thanks again for taking the time to share your knowledge! :blush:
