Door & Window Sensors - Creative Uses?
Anyone use these guys for things that aren’t regular doors & windows?
Thinking of how I can use them to make sure my young son isn’t getting into anything he shouldn’t be when upstairs
I published a post about my usage a while ago
If you include the P100, there’s a more creative use case I shared :slight_smile:
Hi and welcome @meetkd
Just use the searching option here and you will find already some great and unique ideas for using the door and window sensor- also some other devices got great usecases and hacks :vulcan_salute: :x2fozabcpx9xrbxmdpseb3_61:
Nice thread! @markus, your open-window warning idea is close to what I’m planning. In my first Aqara setup I’ll have 4 rooms with 4 radiators, and I’d like to pair a door/window sensor on the windows with a radiator thermostat in each room, so the heating in that room pauses when a window is opened for airing and resumes once it’s closed.
For those who already run something similar: do you rely on the contact sensor, or is the thermostat’s own open-window detection (based on a temperature drop) reliable enough on its own? And do you add a short delay (e.g. 1-2 minutes) before turning the heating off, so that quickly opening a window doesn’t trigger it every time?
For windows, it is probably rather unnecessary, but for balcony doors, it definitely makes sense. Especially if you have cats that want to go out or come in.
Take a look here, this might also be interesting, and the post about the Air purifier automation triggered also covers a 1 minute delay when opening my balcony door:
My fridge and freezer dont alarm when the door is left open, only has a flashing light. They’re both built in to the kitchen cupboards so I used door sensors on these with automations that flash smart lights and given us a verbal message through our apple homepod/homeview thats nearby
