Guide: Setting Up Your Aqara Smart Lock U400
Dear Aqara Users,
In this guide, we will walk you through the detailed steps to connect your Aqara U400 to the Apple Home app and the Aqara Home ecosystem, including how to bind it to an Aqara hub.
We want this guide to be as helpful as possible. If you find any steps unclear or if you have questions that aren’t covered here, please leave a comment below. We are committed to assisting you and resolving any issues you may encounter. Your feedback is invaluable to us; it helps us understand real-world experiences and allows us to continuously improve our products for everyone.
Thank you for your support!
Before You Begin: Our Recommended Setup Order
For the most stable connection and the best user experience, we recommend following these steps in order:
  1. Initialize the Lock: Start with the lock in its factory default state.
  2. Step 1: Bind the lock to the Apple Home app first.
  3. Step 2: Bind the lock to the Aqara Home app via Bluetooth.
  4. Step 3: Finally, connect the lock to an Aqara Thread-enabled Matter Controller (such as the Hub M3) for full smart home integration.
Chapter One: Binding to Apple Home
Pre-Connection Checklist
Before you begin, please verify that your hardware and software meet the following requirements. This ensures the Matter-over-Thread connection works correctly.
1. Device & Software Requirements
To use the U400 with Apple Home, you need a Thread-enabled Apple Home Hub updated to the latest software. Compatible hubs include:
  • Apple HomePod (2nd generation)
  • Apple HomePod mini
  • Apple TV 4K (2nd generation)
  • Apple TV 4K (3rd generation, Wi-Fi + Ethernet)
Supported Apple Devices:
  • iPhone 11 and later, excluding iPhone SE (2nd and 3rd generation) and iPhone 16e, running iOS 18.5 or later.
  • Apple Watch Series 6 and later, excluding Apple Watch SE, running watchOS 11.5 or later.
  • For the smoothest performance, we highly recommend updating to iOS 26 and watchOS 26.
2. Networking & Environment
  • Enable IPv6: Ensure IPv6 is enabled on your Wi-Fi router (this is required for Matter).
  • Same Network: Your iPhone and Apple Home Hub must be on the same Wi-Fi network.
  • Bluetooth: Keep Bluetooth ON on your phone during the entire process.
  • Proximity: Stay close! Keep the lock within 5 meters of your Thread Border Router (HomePod/Apple TV). If there are walls in between, try to stay within 3 meters.
  • Home Setup: Ensure your Apple Home Hub is already set up and visible in the Apple Home app.
The Step-by-Step Binding Procedure
We recommend setting up Apple Home first. Once this is complete, you can easily add the lock to the Aqara Home app via Bluetooth (using the Aqara MagicPair code) to access advanced settings.
  1. Reset the Lock: Press and hold the Reset button on the lock for 5 seconds.
  2. Enter Pairing Mode: Press the Set button once to wake the lock and activate pairing mode.
  3. Add to Apple Home: Open the Apple Home app, tap the “+” icon, select “Add Accessory,” and scan the Matter Pairing Code located on the lock.
Troubleshooting: What to do if pairing fails
Don’t worry if it doesn’t connect on the first try. Here is how to get back on track:
  • Check device compatibility and software versions:: Please verify that your Thread-enabled Apple Home hub, iPhone, and Apple Watch are compatible and running the latest supported software.
  • Retry the Basics: Repeat the steps above one more time. Small signal interruptions can sometimes cause a timeout.
  • The “Deep Reset” Method: 1. Reset the U400 lock. 2. Reset your Apple Home Hub. 3. Re-add the Hub to your “Home” in the app. 4. Wait until the HomePod status shows “Not Playing” in the Home app (this indicates it is fully booted and idle). 5. Attempt the binding process again.
Visual Guide: Binding to Apple Home
Chapter Two: Binding to the Aqara Home App & Add an Aqara Hub
Once your U400 is connected to Apple Home, the next step is to bind it to the Aqara Home app. This unlocks advanced configuration options and allows for Matter-over-Thread integration via an Aqara Hub.
Note: An Aqara Thread-enable Matter Hub is required for Matter-over-Thread integration
As of late 2025, the following Aqara hubs support this integration:
  • Aqara Hub M3
  • Aqara Hub M100
  • Aqara Hub M200
  • Aqara Doorbell Camera Hub G410
  • Aqara Camera Hub G5 Pro
More devices will be supported in 2026. Stay tuned.
  • Bluetooth: Must be enabled on your phone.
  • Network: Your phone and Hub must be on the same Wi-Fi network.
  • Proximity: Ensure the lock is within 5 meters of the Hub M3 (or 3 meters if there are walls in between).
  • Hub Readiness: Your Aqara Hub should already be added to your Aqara Home app and updated to the latest firmware.
  • Region Check: Ensure your Aqara account region is set to a supported location (US, Canada, Singapore, Australia, or New Zealand).
    • Path: Profile > Settings > Region.
Step 1: Bind to Aqara Home via Bluetooth (No Aqara Hub required)
  1. Press the Set button once on the lock to enter pairing mode.
  2. Open the Aqara Home app, tap “Add Accessory,” and select Smart Lock U400.
  3. Scan the Aqara MagicPair code on the lock.
  • :bulb: Pro-Tip: Use your finger to cover the Matter Pairing Code while scanning to ensure the app reads the correct code.
  1. Follow the on-screen prompts to complete the Bluetooth setup.
Visual Guide: Binding to Aqara Home via Bluetooth
Step 2: Connect to the Aqara Hub (Matter Integration)
  1. In the Aqara Home app, open the U400 device page and tap the Cloud icon.
  2. Tap “Connect” and select “Join Aqara Home through sharing.”
  3. Select “Apple Home,” then tap “Enter Matter Pairing Code.”
  4. Switch to the Apple Home app: Go to the U400 settings and tap “Turn On Pairing Mode” to generate a code.
  5. Manual Entry (Important): Switch back to the Aqara Home app and manually type in the code generated by Apple Home.
  6. Press the Set button once on the lock, select your bound Aqara Hub, and follow the final prompts to complete the binding.
    Note on Pairing Codes: Currently, you must manually type the Matter pairing code into the Aqara Home app. The “Copy and Paste” function is not supported for this specific step at this time. We are working on a fix to make this easier in a future update!
Visual Guide: Binding Your Aqara Hub
Remote Features & Automations
After everything is set up, you’ll be able to remotely control the Smart Lock U400 and create automations that suit your personal preferences.
we currently support the following remote features, please check:
  1. Remote Periodic Password
  2. Locking/Unlocking
  3. Check Lock status
  4. Check Battery level
  5. Automations
  6. Set Linked Devices
PS: I’m actively working on more onboarding guides and will continue updating them step by step. Thanks for bearing with me. :raised_hands:
Thank you for the detailed guide. :v8ztqyzclv69n7h2srutpj_46562:
That guide is very well laid out. Thanks for making it as easy as possible to setup and use!
Okay I see
I am unable to bind the Aqara U400 to the Hub M3 via Matter if the lock is already added to Apple Home. Following this guide, I get stuck at Chapter 2: Step 2: Connect to the Aqara Hub (Matter Integration). I have specifically followed the process outlined above.
Interestingly, the binding works perfectly if the U400 is not already in Apple Home. I have also tested this using the Aqara app on a Google Pixel with the Apple Home Matter code, but the result remains the same. It appears that having the lock active in Apple Home prevents it from successfully binding to the Hub M3.
Has anyone successfully followed this process or added the U400 to Apple Home via Matter as well as bind the U400 to the Hub M3 via Matter using some other method?
Nope, mine won’t work either.
Yes worked for me with both u400 I installed. Also added them to Home Assistant after the steps above.
I actually figured this out the night before you guys posted this. I wish I had this earlier. I’m glad I was finally able to get mine connected to Apple HomeKit to make use of UWB.
There’s only one issue that I am having is that I can’t change any settings on the lock remotely. It can only be done through Bluetooth and not through the Aqara m3 hub. Will there any be some type of fix where we can pair it through the Aqara hub first and then to Apple HomeKit?
You can’t use the same Matter code to add a device to multiple platforms like HomeKit, the Aqara app or Home Assistant.
For example, if you’ve started adding the U400 using Matter to HomeKit you’ll need to go to the device’s parameters in HomeKit and select the share function. This will generate a temporary Matter code which you can then use in the Aqara Home app.
i like the u400
It happened to me as well, I had to remove from Homekit, reset the lock and start all over again.
To reset, I had to press BOTH the reset and the set button for 5 seconds. This took some time for Aqara support to figure out as instructions only guided to press the reset button. Then I proceeded to add the lock.
After a couple of failed trials here’s my recommendation: Pair the lock via bluetooth into the Aqara app before adding into Apple Homekit - this is important: if in the middle of the process you get a pop-up asking whether you’d like to add the lock into Apple Homekit just close it and finish the set-up (so proceed to adding your master code, calibrate, etc) and once you added the lock you can then add to Homekit or to Aqara hub (or both!)
So Matter-over-Thread integration doesn’t work with any other vendor’s Thread border router, e.g. Apple HomeKit, Open Thread Border Router, etc. ? Matter-over-Thread is supposed to be an open standard with broad compatibility. Why does it not integrate with an Apple TV’s Matter-over-Thread integration?
Well? I guess I read that as if you want to use the additional advanced features you need an Aqara Thread enabled Matter Hub.
Thread over Matter still works without the M3 Hub, more specifically you can’t unlock the door from remote locations without the Aqara M3 Hub.
IDK? Maybe I am reading that wrong. I didn’t understand that one either when I first read it.
It needs clarification…
You CAN remotely unlock without an Aqara hub. You just can’t unlock it using the Aqara app.
I currently use a Google Nest Hub as my thread border router and was able to add the U400 to Google Home, Apple HomeKit, and Home Assistant. And Im able to remotely lock/ unlock the device from all 3.
I cannot get my lock to finish setting up in HomeKit no matter what I do.
This guide did not help. I reset my lock and tried following this guide, spending almost 2 hours on it, and never got past the point of the lock “Setting up” in Apple Home. I had to reset it again and add it through the Aqara app just so I could use the lock when leaving my house.
When adding it through the app first, I can pair the lock with HomeKit, but it never finishes the setup process. It gets stuck on the “Access Codes” screen and just spins endlessly.
It does add a key to my wallet that I can use, but since the lock isn’t full setup, I can’t share it with anyone else in the home. The lock shows in home as “No response” so it can’t be remotely controlled by anyone in Apple Home.
I had high hopes for this lock, but after spending $270 on this, and $130 on the M3 hub, only for it not work as described, I’m doubtful I’ll be keeping it. The conflicting information in the setup guide, this forum thread, and various Reddit threads make it clear that no one, including the Aqara team, have a clear understanding about how to get this device properly configured with Apple HomeKit.
This is such a disappointing and frustrating experience.
Dear Aqara User,
We sincerely apologize for the frustration and inconvenience you have experienced with the setup process. We understand how disappointing it is when a high-end device does not work as expected, especially after investing in the ecosystem.
Please note that while our setup guides cover the general process, individual results can vary depending on home network environments, hub placement, and iOS versions.
If you are getting stuck on the “Access Codes” screen or seeing a “No Response” status, we need to troubleshoot the connection between the lock, your Hubs, and HomeKit.
Troubleshooting Your Connection
To help us pinpoint the exact cause of the failure, could you please provide the following details?
  1. iPhone Details: What is your specific iPhone model and current iOS version?
  2. Apple Home Hub: Do you own a Thread-enabled Apple Home Hub (e.g., HomePod mini or Apple TV 4K)? Is it placed within 5 meters of the door lock?
  • Note: The “spinning” issue on the Access Codes screen is usually caused by an unstable network connection between the lock and the Apple Hub.
  1. “No Response” Diagnosis: This status usually occurs in three scenarios:
  • There is no Thread-enabled Apple Home Hub in your home.
  • The Apple Home Hub is too far from the U400 lock and no nearby Thread-enabled hub to build the Thread network connection.
  • Direct Phone Connection: If you have an iPhone 15 Pro or newer, you may be able to bind the U400 directly without a hub. However, without a dedicated Thread Hub nearby (within 5m and free of obstructions), the lock will quickly drop offline and show “No Response” whenever your phone moves away.
Proposed Solution (Using your Hub M3)
Since you own the Hub M3, I highly recommend resetting the setup and trying this specific order to ensure stability. This method uses the M3 to bridge the connection when the Apple home hub is placed too far:
  1. Add the U400 lock to the Aqara Home app via Bluetooth first.
  2. Bind the lock to your Hub M3 to complete Matter integration within Aqara Home.
  3. Share the U400 from Aqara Home to Apple Home as a Matter accessory.
Important:
  • The Hub M3 is required to be placed near the U400 lock.
  • Ensure your Hub M3 and your Apple Home Hub are connected to the same Wi-Fi network to achieve Apple Home control.
Please refer to the guide below. It details how to use your Aqara Hub (placed closer to the lock) to establish a stable Thread connection: Aquara U400 not binding to M100
We are committed to getting this working for you. Please let us know the details requested above, and we will guide you through the next steps.
I think it’s important to specify when listing the Apple TV 4K that it’s ONLY the 128Gb WiFi+Ethernet model that has the Thread networking.
My setup is with HA. I was able to add the U400 to my thread network without any issues… The issue is getting it to stay connected.
After binding it to my matter network it then becomes unavailable about about a day.
The issue is not my thread network either since I have a inovelli switch about 3 ft away from the lock that doesn’t have any connection issues.
I do have it bind to the Aqara app via BLE and it’s currently running firmware 3.1.0.7 beta.
Any insight as to way it connects to my network without issues but then fails to remain available? (I’m completely new to matter and home assistant so it could definitely be user err).
