Smart Lighting That Adapts to Seasons: Day/Night Scenes with Aqara Automation 2.0
Setup
  • Hub: Aqara Hub M3
  • Lamp: Aqara T1M (ceiling, RGBW + tunable white)
  • Switch: Aqara H2 (single channel, logical mode)
  • App: Aqara Home with Automation 2.0
The Problem
When I first set up my child’s bedroom lighting in late winter, I created six time-based scenes:
  • Early Morning: 06:00–07:00
  • Morning: 07:00–08:00
  • Day: 08:00–16:00
  • Early Evening: 16:00–18:00
  • Evening: 18:00–21:00
  • Night: 21:00–06:00
It worked perfectly in February. But as spring arrived, I noticed something wrong: at 16:00, the automation was switching to “Early Evening” mode — warm, dimmed light — while outside it was still bright daylight. In summer, sunset in Warsaw is around 21:00, so “Early Evening” would fire nearly 5 hours before it gets dark.
The root issue: fixed time boundaries don’t account for seasonal changes in sunrise and sunset.
The Solution: Two Parallel Scenes with Acting Time
Instead of one scene with fixed times, I created two parallel scenes using the Acting Time feature from Automation 2.0:
  • “Daylight” — Acting Time: Day (active from sunrise to sunset)
  • “Nightlight” — Acting Time: Night (active from sunset to sunrise)
Each scene contains its own set of time slots and lighting effects. They run in parallel but only one is ever active at any given moment — Aqara handles the switching automatically based on the sun’s position.
:open_book: This approach uses the scene scheduling system described in Automation 2.0, Lesson 4 (Scene with time-based light sequences):
Automation 2.0. Lesson 4. Lighting control by time periods
Scene Structure
A parent scene “Main Light” calls one of the two child scenes depending on the time of day. This gives a single entry point — one scene to assign to a button, a voice command, or any automation trigger.
"Main Light"
    ├── "Daylight"  (Acting Time: Day)
    │       ├── Early Morning                       05:00–06:45
    │       ├── → Early Morning–Morning transition  06:45–07:00
    │       ├── Morning                             07:00–07:45
    │       ├── → Morning–Day transition            07:45–08:00
    │       ├── Day                                 08:00–15:45
    │       ├── → Day–Early Evening transition      15:45–16:00
    │       └── Early Evening                       16:00–21:00
    └── "Nightlight"  (Acting Time: Night)
            ├── Morning                             07:00–08:00
            ├── Evening                             16:00–20:45
            ├── → Evening–Night transition          20:45–21:00
            └── Night                               21:00–05:00
Each scene slot uses an existing lighting effect (static white with tunable color temperature, dynamic color, or transition effect). No new effects needed — just reorganized into two acting-time groups.
The gap periods (e.g. 09:00–16:00 in Nightlight) are intentional — Acting Time: Night is inactive during those hours anyway, so nothing fires.
How It Behaves Across Seasons
Time Month Sun position Active scene Result
18:00 June Above horizon Daylight Early Evening :sun_behind_small_cloud:
18:00 December Below horizon Nightlight Evening :crescent_moon:
17:00 October Above horizon Daylight Early Evening :sun_behind_small_cloud:
19:00 October Below horizon Nightlight Evening :crescent_moon:
16:00 December Below horizon Nightlight Evening :crescent_moon:
The system automatically adjusts every day without any manual changes.
Lighting Effects Used
Scene slot Color temp Brightness Notes
Early Morning Dynamic color — Blue-green tones, dynamic effect
Morning 4694K 60% Warm white, moderate
Day 5000K 100% Neutral white, full brightness
Early Evening 3164K 45% Warm, dimmed
Evening 2777K 30% Amber, low
Night Red 10% Static, minimal
Transitions between slots are 15-minute gradual effects built as separate effect sequences inside each scene.
Key Takeaways
  • Acting Time: Day / Night is the core mechanism — Aqara calculates sunrise/sunset automatically based on hub location, no manual updates needed ever
  • Parent scene as a wrapper simplifies everything — one scene to assign to a button, voice command, or any trigger
  • No duplicating effects — same lighting effects are reused across both scenes, just arranged differently
  • The two scenes overlap in clock time but never conflict — only one Acting Time is ever active at once
Known Limitation
In Warsaw, summer civil twilight starts around 03:45. This means Acting Time: Night ends very early, and the Nightlight “Early Morning” slot (starting 05:00) has a gap. A workaround is planned — either shifting the Early Morning boundary or adding a separate condition.
If you have a similar setup or found a cleaner solution for the summer gap — would love to hear it in the comments.
Hello, thank you for such an extensive review.
From my side, I recommend you to turn to lesson 9. Maybe it will suit you too, I use this method intensively at home, it works flawlessly. Automation 2.0, lesson 9, (blitz topic of the addition to lesson 4) using group control of lamps using scenes
What an amazing setup! :star_struck: Thanks for sharing!
Really well done! Think this is really cozy and practical in day to day operation as well!
Wouldn’t it be better to add adaptive lighting to the application?
That’s such a creative way to fix your issue! Thanks for sharing!
