Suggestions for improving Aqara products
Suggest your ideas for improving certain Aqara products.
Please add the ability to control the lamp (aqara ceiling light t1) on the S1e panel
Please add PTZ calibration to the main page of the G3 camera, as they did in the E1 camera
Dear developers, I am waiting for the work of the Aqara app locally without the need for the Internet.
There is a lack of a local hub that will work in the home network without the need to enter the cloud.
Please add the ability to create groups for matter devices. This will greatly facilitate the use of matter lighting and products in general in Aqara home.
I have a suggestion for the future development of TVR Aqara. The main drawback of the current version is the lack of setting the TVR operating mode without hysteresis (0°C), I call this parameter the “valve” operating mode. The premise of the question: if TVR Aqara is used in heating systems with individual heating (a boiler (gas, electric) works for one private house), it cannot be used on a radiator to give an On/Off command to the heating device.
Why it cannot be used: TVR Aqara, when the temperature drops below the set point, does not immediately open the battery but maintains the range of ∆-0.3°C (according to my research), and at this moment the On command is given to the boiler, and the heating radiator is CLOSED, there is NO water circulation!
I assume that more than one buyer of the smart TVR Aqara has encountered this problem.
Groups for all products, and allowed to mix match
Also a home assistant official or hacs integration, you guys just have to look at the amount you f devices compared to what’s on peoples hubs to realise how many devices are registered in home assistant.
Automations
I would like to see
Start/trigger
Condition (multiple option select so you can say either so condition will allow multiple and only one has to match
Execution this is a big one I would like to see similar to if then do this (with else option)
A proper kitchen light over 1.4 meters long and 30cn wide and defused but also super bright white as well as color option. I have something it cost 130 but is crappy tuya and I had to flash it to be tassuma
A kit for stairs for light chase up the step, it’s nice but options cost way to much and I have done it cheaper using your motion sensors
Thank you for your valuable suggestions! Aqara’s Product Managers will certainly visit the forum and listen to everyone’s feedback, continuously refine our products, and create an even better experience to all Smart Home Users. :pray::pray::pray:
Normal localization of translations is required, in the region of Russia sometimes you see a very ridiculous translation, for example, here is one of the examples on the pericardium G5, there is no such thing as “package guard” in the Russian language and this is not an isolated case, if you switch to English, the concept of what is written is correct, as I wanted the translation into languages to be translated not by a translator but by a person who knew that there are no such words in the languages of other countries. Thank you
The Aqara app lacks Apple CarPlay support. I hope you will consider the possibility of adding this direction.
Please add the ability to add a tile of the new W500 thermostat to the S1 plus EU panel and Aqara Touchscreen Dial V1
Hello, we have paid attention to your question, will arrange as soon as possible Aqara Touchscreen Dial V1 and S1 plus support the association of the new product W500。
Please add the new T2 Bulbs for Mars Tech support on Panel Switch S100
Aqara w500 please add support for 12k ntc sensors
I would love to see dimming option on Touchscreen Dial V1 EU. It can control dimmable lights, but cannot act as physical dimmer itself which doesn’t make sense.
I planned to have them in each room in place of main light switch controlling Radiator/AC, shutters and light (as dimmer).
Make S1 Panel Plus to be able to import data/widgets from HA. Really, make it more open!
Are your radiators connected to the boiler correctly?
It would be really helpful to have an option in the Aqara app to enter electricity prices. That way, when using devices like the W500 thermostat, I could view not only the daily and monthly energy consumption in kWh, but also the corresponding cost in my local currency.
Hi, I just described this in lesson 11 ( Automation 2.0, lesson 11, creating the simplest automation for heating devices ). Top picture “B”, bottom “C”
How about making Weather Widget actually useful on s1 panel??? Can you people make it show day/night/hourly + 3 day forecast? This is the most expensive useful product I’ve ever had.
