W100 + E1 valve
Hi everyone,
I have several rooms in my house where there are 2 or 3 radiators equipped with Aqara E1 thermostatic heads. I’d like to know whether it’s possible — and mainly functional — to connect multiple E1 heads to one external temperature sensor Aqara W100, so they all work based on its temperature measurement.
Has anyone tried this setup or knows how to configure it properly so that all radiator heads in one room respond according to a single external temperature sensor?
Thanks a lot for your help,
Robert
Hey there!
I’ve been testing the Aqara W100 together with some E1 thermostats, and I wanted to share a few tips on how to properly connect temperature sensors and thermostats.
Some of the logic behind this setup isn’t immediately clear, so here’s a quick walkthrough that might save you a bit of time. :blush:
Connect temperature sensor to thermostats
Each thermostat must be linked to its own sensor, so just repeat the same steps for each thermostat. It’s also possible to use the same sensor for multiple thermostats, but you have to manually link them one by one.
The name of the W100 should be included in the selection. Select it from the list.
Bonus: If you want to control all thermostats with the W100, here’s how to do it.
Create a device group for all thermostats (optional)
You can create a group if you want to control several thermostats at once.
Important: You cannot specify a corresponding temperature sensor for a group. You have to do this individually for each thermostat.
Change the connected thermostat on the W100 (optional)
On the W100, you can decide which thermostats can be controlled.
Important: This is only necessary if you want to control the temperature via the W100 for a group or a specific thermostat. Don’t link the W100 to any thermostat if you want to use its buttons in automations (for example, to control lights).
Change the connected temperature sensor on the W100 (optional)
You can also select which temperature sensor is shown on the W100’s screen.
Important: the temperature sensor connected to the W100 has nothing to do with the thermostats. It’s only the temperature from the selected sensor that appears at the very bottom of the W100 - as shown by the green mark in the picture below.
In my case, I chose a temperature sensor on the balcony so I can keep an eye on the outside temperature directly on the W100.
Just so you know:
  • The temperature shown at the bottom of the W100 doesn’t actually control anything.
  • The small temperature display in the middle shows the setpoint temperature - this is the temperature that your connected thermostats will try to reach.
  • If you want to use the temperature shown at the top of the W100, you’ll need to either link its sensor to a thermostat or use its sensor in an automation.
For example, I have an automation that switches off all thermostats whenever the outside temperature rises above 18 °C. Or you could use the W100 sensor to make a light blink when the indoor temperature drops below 15 °C.
To:JohnD
I think it’s a perfect guide; I never thought about grouping the devices into one group. Thanks a lot again for your help!”
Moin @JohnD ist das auch bei dir passiert?
Nein, bisher ist alles in Ordnung.
Aber mein Setup ist derzeit auch ein bisschen anders:
  • E1 Hub statt M3
  • W100 ist derzeit an kein Thermostat gebunden, da ich die Buttons per Matter in Home Assistant für verschiedene Szenen verwende
  • Ein Thermostat verwendet den W100 als Temperatursensor
  • alle anderen Thermostate nutzen „normale” Temperatursensoren von Aqara
Betrachte ich jedoch die Zigbee-Signalstärke aller beteiligten Geräte über einen Zeitraum von einer Woche, kommt es bei mir zu keinen Aussetzern. Die Verbindungen sind durchweg exzellent.
Vielleicht kommt es bei dir nur kurzfristig zu Aussetzern (Nachbar schaltet die Mikrowelle ein :wink: ) und der Sensor verbindet sich nicht erneut. Ich gehe davon aus, dass die Verbindung wiederhergestellt wird, sobald diese wieder verfügbar ist. Vielleicht liegt genau da der Knackpunkt, dass das nicht richtig funktioniert? Das würde deine Situation jedenfalls erklären, wenn der Sensor getrennt ist, die aktuelle Empfangsstärke aber gut ist.
Ganz nebenbei bemerkt: Ich hatte mit den E1-Thermostaten immer wieder Probleme mit normalen Batterien. Deshalb bin ich auf Lithium-Ionen-Akkus gewechselt und habe seitdem keine Probleme mehr. Lithium-Ionen-Akkus halten ihre Spannung deutlich besser.
Danke für deine Antwort. Das ist ein gute Tipp, Lithium-lonen-Akkus. Gut zu wissen. Ja habe diese Verbunden Problem seit wann ich habe E1 und W100 zusammen eingestellt.
Hello, as we found out together with @gtxteo, I recommend setting the W100 polling time to 10 minutes, this setting will prevent a failure (disconnection from E1) in the connection between E1->W100.
Are thermostat groups currently broken or just completely useless?
I have a handful of W600 radiator thermostats and one W100 climate sensor. The app will allow me to create a “Radiator Thermostat Group (compatible with E1 and other thermostats” but then cannot use the group for anything. There is no device card, just a blank screen. I cannot set the W100 to control the group, only one single W600. I cannot use the group to trigger an automation, nor target the group with any action.
Utterly disappointing…
It definitely works with the E1 and the W100. Unfortunately, I can’t say anything about the W600 as I don’t have one.
However, take a look — there’s already a post on the topic here. You might get some help there.
