The camera is running out of battery in 5 to 6 days. It is not detecting any movement events during the day, does not save video to the microSD card, it is set to Power save mode, the lingering option is set to 1 meter with an event of 10 minutes, so it needs 10 minutes of something moving to start recording. No sure what else to do. Half of the day is under the shade. WiFi bars are 3 out of 5. Any suggestions are welcome. Im just about to disconnect the thing.
Bear in mind that the battery life depends on the type of batteries you put in the G410. NiMH batteries have a low starting voltage, which is problematic. For example, six cells provide only 7.2 V, whereas alkaline batteries provide 9.0 V.
There are already posts on this topic here.
For example, take a look at:
If the doorbell still only works for 5-6 days in power-saving mode, I believe there may be hardware issues or other reasons that prevent the doorbell from entering sleep mode. Please confirm if the following conditions exist:
Have you connected the doorbell to HomeKit and enabled iCloud storage? If so, are there any devices running the home app (iPhone, iPad, iWatch, Apple TV, etc.) that keep live streaming or updating cover images?
When someone approaches the doorbell, do the indicator lights around the doorbell button turn off or remain on in red or other colors?
How far is the distance between the doorbell and Chime indoors? What are the obstacles in the middle (doors, walls, etc.)?
In power-saving mode, the theoretical battery life of the doorbell can even reach one year (with only a very small number of ringing events per day and infrequent viewing of doorbell videos), so I believe the problem you are facing is abnormal.
