🎉 [Seeking Participants] Share Your Experience Using 3rd-Party Matter Devices in Aqara Home & Win Prizes! 🎉
We’re excited to hear how you’ve integrated third-party Matter devices into Aqara Home! Share your setup for a chance to win exclusive rewards. Here’s what we need:
:pushpin: Campaign Period​:pushpin:
6 Months (6.16-12.16)
:pushpin: How to Submit Entry​:pushpin:
:one: Create a Post: Share your Aqara Home Matter system.
:two: Tag Your Post: Use the tag MatterWithAqaraHome to make sure your entry can be found.
:three: Copy the link of the post you created into this event thread for the admin to check.
:pushpin: Submission Requirements​:pushpin:
:one: Device Details
• Brand, model, and type (e.g., smart plug, light, sensor).
• Photos/videos of the physical device.
:two: Aqara Home Integration Proof
• Screenshots of the device added in Aqara Home App (device list/control page).
• List of supported functions (e.g., on/off, dimming, automations).
:three: Your Experience
• How was the pairing process? Smooth or tricky?
• App control feedback: Stability, latency, feature limitations.
• Any issues encountered (e.g., disconnections, unsupported features).
:four: Bonus Points!
• A short video showing the device in action using the Aqara Home App (e.g., controls/automations).
:pushpin: Winners and Prizes​:pushpin:
:one: Anyone with a valid entry will receive a reward of 30 Aqara Forum points (for details on the points system, please refer to the instructions). In the future, points can be freely redeemed for prizes in the Aqara Forum points mall.
:two: Each month, the Aqara Team will select 3 Outstanding Contribution Awards based on the quality of entries, with an additional reward of 50 points for winners.
:three: A user can participate multiple times and earn participation points for each entry, but can receive at most one Outstanding Contribution Award per month.
Seamless Security Lighting with Aqara M3, Camera G5 & Govee H705 via Matter
Thanks for your participation!
Bringing Old Devices Back to Life with Matter, Integrating Non-Matter Tech into Aqara Home
Mill Wifi Panel Heater (Gen3)
MatterWithAqaraHome
World’s first panel heater with Matter. Added it to the Aqara M3 Hub with the Matter code I generated from Mill. It connected to Aqara right away and came up as Thermostart. I can turn it on/off, adjust the temperature and use it in automations. Adjusting the temperature from the Aqara App is pretty quick. So far it looks good, I have more panel heaters I want to connect later. Will test it more in the fall and winter. Mill is coming with a new generation (Gen4) of the panel heaters in the fall (With Wifi/Matter/Zigbee). Hope the new #AqaraSmartThermostatW600 can control 3 party devices.
I can’t even get Aqara’s own matter devices working in the Aqara app. With just and e1 and m2 hub, Aqara’s matter over thread devices won’t work. I keep my Aqara m2 just as a bridge to other open platforms, home assistant, Alexa, Apple home, Google home and hubitat.
You need the M3,M100 or G4.
Aqara Home with Hue Bulbs
MatterWithAqaraHome
I have connected the Hue Bridge/Hub to Aqara with Matter and can control Hue Bulbs. All the lights in the living room are connected to a Hue Bridge/Hub. In the living room I have an Aqara Display Switch V1 EU, I use one of the buttons to turn on/off all the lights using an automation. We use Siri to dim the lights.
Points added!
MatterWithAqaraHome
I added all these devices to Aqara home via matter, thank you for the opportunity to combine everything you need in one application.
#MatterWithAqaraHome
so tapo 304 4 plug one, I also have one of these in aqara m3 hub
uselink 4 way with usb one.
Thanks for participating! Points added.
Aqara home app got alot more better thanks to matter support
Something i hope to see is more icons that will better fit the model of the device (becuase even aqara devices dont have thier icons when connected via matter)
you mean like these
Yes. If connected via matter they don’t show
Aqara Ceiling Lamp T1M
MatterWithAqaraHome
I integrated my Aqara Ceiling Lamp T1M into SmartThings using Matter, since I couldn’t find a way to add it directly otherwise. Thanks to Matter, I was able to bring it in and also trigger my Aqara scenes from SmartThings.
The setup process was mostly smooth - the Aqara side worked well, but I did run into some issues getting my TV to function as a proper Matter hub at first. Once that was sorted, everything connected cleanly.
Now the T1M is part of my SmartThings routines. I’m using Samsung’s Circadian Lighting to match indoor light with natural daylight, and I also paired it with my Nest Hub’s morning wake-up light feature - so both lights slowly brighten.
One fun routine I set up: the T1M’s colorful outer ring changes color based on the current weather outside - super helpful (and lazy) way to get a weather check without even looking at my phone or window :joy:
I also linked my Ring Doorbell to SmartThings so that when someone rings the bell, the T1M flashes red to grab my attention.
Thanks for sharing! Points have been issued. :grinning:
MatterWithAqaraHome
I managed to add a Thread bulb Nanoleaf Essentials A19|A60 (without matter support) to Aqara home via HA MatterHub.
The bulb works great in Aqara home, the response is fast.
